Gerald Elkin
House Finch
Oil for Achro lens element spacing
Started by Tom Mengel, 01/04/2013 10:12AM
Posted 01/04/2013 10:12AM Opening Post
I got a Surplus Shed 110mm f4.5 Achro that seems too be a pretty good lens but is a bit over corrected. Over on CN someone posted that this lens was actually designed for cement between the elements and suggested using oil between the components as a experiment. Does any one here have any suggestions as to what kind of oil to use? I'm thinking just plain old fashion clear mineral oil from the local pharmacy will have a close enough index of refraction and if it does improves the performance then go with UV cured lens cement for a more permanent solution.
Any suggestions appreciated - Thanks!
Tom Mengel
Moderator Equipment Talk
“Insanity: Trying the same thing over and over and expecting different results”.
Albert Einstein
Posted 01/04/2013 04:09PM #1
Even a few drops of salad oil will work for your experiment and it will save a trip to the store. Does anyone still use mineral oil for its intended purpose? 8O
Jim McSheehy
