I'm using the LX-200 Classic permanently polar aligned on a pier in an observatory. I'm used to doing a simple one-star alignment with my LX-200 classic, since the pier is polar aligned. With the classic, if you have a good polar alignment, you can just sync the telescope on one star, and you're good to go.
I just upgraded to the LX-200 GPS, and need help with a simple alignment procedure. Meade tech support indicates that there is a way to do this with the LX-200 GPS, but I can't figure it out from the user's guide, and would appreciate any help.
In the LX-200 user's guide, "One-star polar alignment" it indicates that the telescope prompts you to go to Polaris. That's a big problem for me, because I have a large CCD camera (the SBIG STL-11000) and can't swing the camera through the forks to Polaris without removing the camera.
So I want to avoid any procedure that requires going to Polaris and sync on a single star.
For those of you who have the LX-200 GPS permanently mounted in an observatory with a good polar alignment, what is your procedure for a one-star alignment?
Thanks for any info.
Clear skies,
Rob,
Charlottesville, VA
Clear skies,
Rob,
Charlottesville, VA
