Opinions on Apogee
Started by joebryan, 03/22/2004 12:41AM
Posted 03/22/2004 12:41AM Opening Post
In my quest to purchase a beggining refractor scope for me I have been pricing all types, how does the Apogee brand compare to say Celestron or Meade? I'm looking at the Widestar 90, or perhaps a standard 80 or 90mm refractor,
long tube, Thanks.
Posted 03/22/2004 02:50AM #1
long tube, Thanks.
I suggest looking elsewhere if you are not looking for a bargin. I have one their original $99 ST-80 clones, not so bad, took some work to make it work but it provided some nice views. The newer ones have plastic focusers.
Lots of scopes in these size ranges. Someone suggested the StellarVue scopes. At this time, I think the Orion ED80 is a better way to go, similar price but color free performance in an F7.5 scope, fast enough to be a widefield scope but with its color free performance it will do a nice job on the planets as well.
jon
Posted 03/22/2004 02:50AM #2
You won't go wrong with Stellarvue. I'd recommend the 80/9D on an M4 mount to anyone looking for a small achromat. Maybe more expensive than Apogee, but worth every dime.
Posted 03/22/2004 04:07AM #3
The Widestar 90 is an achromat, so don't expect the performance of an Orion80 ED - something that you'd be paying 3 times the price for, for the optical tube alone.
That said, achromats usually provide fairly reasonable views of DSOs at low power.
Erect image diagonals are handy for finding one's way around in the sky, especially for a beginner. But they usually degrade the views significantly compared to a standard prism or mirror diagonal. So, if you get the Widestar, make sure you also get one of Apogee's cheap (but pretty good) 1.25" 90 degree mirror diagonals as well.
For high power viewing of the moon and planets, expect to see an image-degrading blue halo. Fortunately, you can sharpen the image a bit by using a No 12 Yellow filter, to eliminate most of the blue.
As the others have said - you get what you pay for.
Renato
Posted 03/22/2004 04:57AM #4
If you're on a tight budget, I think you'd be happier with something like Orion's 4.5 inch Dobsonian mounted reflector at $199. It'll give somewhat brighter images and won't have the "purple halo" on bright objects that the Widestar 90 would have.
Those "Widestar"-type refractors are good for very wide fields of view, and are nice second telescopes when your primary scope isn't so good at wide-field viewing. But as a general purpose scope, the 4.5 XT is an all around better performer and in the same price range.
Apogee as a brand is actually probably a little better than you might expect for the price. The don't sell junk, and you're far better off with Apogee than typical department store offerings. But if you have the money, similar scopes from, say, Stellarvue, will make you happier in the long run.
