Which CCD are you planning on using, a cooled CCD or a webcam type?
One thing to consider is that this scope has terrible false color. It is barely passable visually at lower magnifications.
CCD cameras capture a much broaded range of wavelengths so the false color will be significantly worse. One would definitely needs some serious filters.
I have a Orion Spaceprobe 130 ST fitted with a 2 inch focuser that I use for some "casual" CCDing. This is a 130 mm F5 Newtonian and I use it with a 1.25 inch Paracorr at times, though that is not needed. The camera is similar to a ST-237, uses the same chip and has two stage Peltier cooling.
I have attached a single 30 second exposure of M42-M43 done in my backyard which is in the middle of San Diego, pretty severe light pollution.
Personally I think a Newtonian makes better sense than a fast large achromat, most CCDs have small chip sizes so coma is not an issue and being free of false color, they provide better images.
