Wizard Nebula
Orion AstroView EQ Mount question
Started by moutinho, 06/13/2004 09:50PM
Posted 06/13/2004 09:50PM Opening Post
Is the Orion AstroView EQ Mount (not pro) suitable for astrophoto exposure up to 1 minute using a mod webcam ?
Andre
Posted 06/13/2004 10:05PM #1
Andre,
What scope are you using on the Astro View?
Posted 06/13/2004 11:19PM #2
I have an Astroview EQ mount (actually the EQ-3) and have used a variety of scopes on it. The problem I found was that the drive motor causes some vibration as it steps along. With the original 120mm F8.3 refractor this was sufficient to require stopping the drive in order to get a clean split of the double-double.
These days I am using an Orion Space Probe 130ST, a 130mm F5 Newtonian, with the legs as short as possible, it does an adequate job, splitting the double-double is clean at most any magnification.
The problem seems to be in the tripod. If I mount the head on a high grade heavy duty tripod, there are not vibration issues.
Given the high magnifications/focal length one normally uses with a web cam, I would be concerned using my Astroview.
jon
