Ghost of Cassiopeia
Orion XT10 or Celestron Starhopper 12
Started by astroman305, 05/19/2004 08:39PM
Posted 05/19/2004 08:39PM Opening Post
Hello Fellow Astronomers!
I've been attacked by the "aperture fever" bug, and i can't find a long term cure except for this. I'm currently using a 1976 Celestron C8 Orange Tube telescope, that was generously given to me by some wonderful friends. I'll i had to do was clean is up, give is a makeover, and take it out. The optics are in perfect shape, but like i said i want a bigger scope. I'm deciding between the Orion XT10 Dob, and the Celestron Starhopper 12, and so i turn to you guys for some input. I'm looking to spend no more the $1000. wink The other thing i want to do is mount a 80mm refractor to the scope, due to, i enjoy low power wide field sweeps now and then, and i don't want to run back and forth, scope to scope, just to see what i was looking at. 8) So, now, price was another factor. The Orion XT10 dob comes in at $549, which leaves me money for the 80mm refractor setup i want, which is the Orion Astrophoto Guidescope Package. I like that setup, due to the fact that is has the scope rings and mounting plate, plus a few other goodies if i want to go CCD in the future. The Celestron Starhopper 12 comes in at $925, with shipping, and i would have to spend $300 more for the 80mm. The question i have is which will be "better bang" for the buck. All i care about is deep space hunting, Seeing, and clarity, ie. how sharp an object appears is also important. wink Also, moving up from a C8 to a 10" Dob, will i see a difference in brightness, or "how well" i see an object? 8O
Thank you very much for your time.
Robert
Posted 05/19/2004 11:57PM #1
The general advice I have heard repeated many times is that for the biggest "WOW" factor you should move up 2 sizes (from 6" to 10" or from 8" to 12"), but if it were up to me I would probably take the 10" dob over the 12" dob due to my personal preference with portability. I couldn't see myself lugging a 12" dob down the stairs of my apartment very often but your circumstances might be much different than mine. You also mention wanting to mount Orion's 80mm guide scope refractor on top of either of these dobs. A lot of people do this with short tube refractors but I don't think Orion's guide scope at f/11.3 would be a very good choice to mount on top of a dob. It's focal length is 910mm which will put the eyepiece very near the ground on the XT10 unless you have the refractor extending way past the open end of the dob's tube (which might cause some balance problems). I don't know the focal length of the celestron 12" but I imagine it's not too much longer than the Orion and you might run into a similar problem. Besides, f/11.3 is not going to give you a very wide field of view either. Have a look at Orion's short tube 80mm, I think it will serve your purpose much better.
Posted 05/20/2004 12:44PM #2
Robert,
An obvious visual difference between the SCT at 2000mm and the 10" at 1200mm will be the field of view. With a wider field of view in the 10", it should be easier to find objects, but you might experience less contrast at the lower magnification. Cool down will also be better, although I depend on a fan system to cool my 10". A 12 inch scope gets big real quick. If you don't have to move the scope too far to get it to your observing area, then a 12 inch will resolve more for sure and will be a big step above the 8".
Good luck,
Chase
Posted 05/20/2004 04:50PM #3
Robert:
This is my thinking as the owner of XT-8, a OPT Starhunter 10 (10 inch F5) and 12.5 inch Discovery DOB...
1. Concensus seems to be that inch for inch, Newts are slightly brighter than SCTs, especially older ones...
2. The difference between each step is significant, both in capability and in size/awkwardness. My 12.5 incher is F4.1 so the OTA weighs only 48 lbs and is 52 inch long....
The main issue is whether you yourself are willing to deal with the awkwardness of the larger OTA. That 12 inch Celestron OTA is 57 inches long, it takes up a lot of space in a car and is a job getting it in and out.
There is not doubt that the 12.5 incher is the best when it comes to DSOs.
3. Not sure about mounting the ST-80 on the OTA, that is going to cause significant problems with balance. To make the scope work right you would probably have to add 6-10 lbs to the mirror end and then it must be properly distributed between the focuser side and the bottom side or the scope will need constant rebalancing as you change altitude.
I like a Telrad+an 8x50 finder and a separate tripod for the small refractor.
Bottomline: Don't buy one of these scopes without looking at one first, they are big.
jon
Posted 05/20/2004 08:59PM #4
Robert,
I have an 8" Newt on an EQ with dual axis drive. Setting up next to a 10" dob on a couple of occasions, it seemed my view was as good or better then the 10" dob. It could be any number of factors (EP, particular scope, dust on mirror, ....) but it made me think that since mine was tracking and the object not moving in my view, then I could settle in a bit more and the view got better.
Depending on the size issues I would say go with either the 12" Starhopper or the 13" Coulter or sink a little into the C8 to clean it up and possibly get the glass coated. Gut feel, you will not see much difference between the 8" and 10" and you'll spend a few hundred bucks to find this out.
Ed
Posted 05/23/2004 11:56AM #5
Wow. Cool. Thanks for all the info folks. I will probably go for the XT10 due to cost. 8) I'll be looking around Astromart to see if i can snag a 12" Dob in the short future. wink
Happy Clear Night,
Robert
