Paracorr turntable top settings
Started by bull, 06/27/2004 03:59PM
Posted 06/27/2004 03:59PM Opening Post
I purchased a paracorr on astromart and now I'm waiting for it to come in. I have been busy looking up information on the internet about this device. The Televue website has a table indicating the different turntable top settings for all the current Televue eyepieces. My problem is that I do not own any Televue eyepieces and I would like to know how to find the turntable settings for my eyepiece collection. I have 13, 17 & 22mm Superwide Lanthanums and a 10.5mm Pentax. I also have both a 2.5x and a 5.0x powermate.
I understand that for the paracorr to work correctly the turntable top must be adjusted for a certain fixed distance between the last element in the paracorr and the field stop of the eyepiece. Unlike Televue my eyepieces don't have published field stop specs.
Does anybody know what turntable top settings I would need for my eyepiece collection?
Does anybody know what is the proper distance between the last paracorr element and the eyepiece field stop?
Can I use the 2.5x and 5.0x powermates with the paracorr?
Is it possible to set the paracorr to the correct focuser position if I know were my mirror's focal plane lies with respect to my focuser? At that point I would just insert my eyepieces in the paracorr and adjust for best focus with the turntable top with maybe some fine focus adjustments with the focuser.
Regards,
Pete
Posted 06/28/2004 12:57AM #1
Basically, most eyepieces will need to have it set at the uppermost position. Eyepieces that need a lot of infocus travel (like Nagler T4's) will need to have the uneable top in the lower position (i.e. providing the extra infocus by moving the top rather than moving the paracorr). The idea is to maintain the ideal distance from the paracorr lens to the focal plane. I think the difference in performance is pretty minimal, though. So I would just try it with your widest FOV eyepiece in both positions, and see which you prefer. Then any eyepiece with a similar focal plane uses the same top position. Any eyepiece that requires significantly more/less infocus gets the lower/higher position.
Jarad
