james carter
North American Nebula NGC7000
Pelican case - foam or divider?
Started by HowardP, 10/24/2004 09:05PM
Posted 10/24/2004 09:05PM Opening Post
I plan on getting a Pelican 1550 to hold 3 pairs of Eps, few single eps, bino, 2” diagonal, big Barlow and a few other small items.
What makes more sense; the dividers that give a nice and clean look or the pre-cut foam that has to be punched out and shaped? Anyone use either system and any recommendations or comments?
Thanks howard
Posted 10/24/2004 09:30PM | Edited 10/24/2004 09:30PM #1
Howard,
I use the pre-cut foam with great success. I have two 1500 cases, which I use to store my 8 1.25" and 2" eyepieces, diagonal and 3" refractor. The pre-cut foam allows me to maximum the space inside, IMO. You can also glue back the punched-out foam pieces to form new shapes, allowing you to adapt the case as you change your accessories.
cheers,
Simon
Posted 10/24/2004 09:44PM #2
I'd go with the foam. Even though the dividers are padded it makes me nervous feeling things rolling around, especially eyepieces. Another option if you have a Lowes near you is their TOOL CASE in the tool section. It's a metal case like the Celestron or Meade and it has pluck foam and diveders so you can fashion it as you please. It also comes with a pocketed tool holder for inside the lid if you like. Nice case for about $30 or less.
Hope this helps
Buck
