Picture time! clips
Started by Ron777, 04/23/2004 12:48AM
Posted 04/23/2004 12:48AM
Opening Post
Posted 04/23/2004 06:01AM
#3
For whatever reason Oregon seems to be a hotbed of ATMing. Richard Berry. Mel Bartels. Steve Swayze, Dan Gray, and Chuck Dethloff (I'm omitting others I'm sure, but you get the idea... I felt it very compelling to become an ATM myself in this atmosphere).
Anyway, amongst all the innovations, I believe Chuck Dethloff was the first to hit on this idea of hiding a fan in the shadow of the secondary, however his execusion instills no fear and as to michael's comment abou this being insane, I think it can only apply to Ron's sticky tape version of Chuck's otherwise solid idea.
Don't throw the baby out with the bathwater. Have a look at my local groups projects, in particular noting Chuck's scope from a couple years ago (seen here at last years OSP)...
http://members.efn.org/~mbartels/osp2003/OSP2003.html
The fan blowing down on the mirror is a very direct and perhaps radically so way of eliminating the thermal barrier. However, Ron, you really should consider screws and not tape for something this precarious or look at the solid way Chuck has done it.
TomL
TomL
Posted 04/23/2004 12:50PM
#4
Ron, if you end up using a spider then here's a tip on delivering electricity to the fan along a spider vane. Find a place that sells doll house stuff, and get a roll of doll house wiring tape. It consists of two copper foil strips, about 1/4" wide each, side-by-side on a self-adhesive backing. Just apply a strip to one of the vanes. The "top" (non-adhesive) side is also covered, but the covering is easily peeled off. You can then clean the top of the copper conductors at each end and solder connecting wires directly on the surface. When done paint with flat black and you can hardly tell that it's there, it's so thin. Much neater and thinner than trying to route and align wires along a vane.
I did this for connecting to the dew heater behind the secondary on my 13" and it works great.
Doug
Doug
Funding Member
