I would like to leave my 8 inch SCT up for up to a few weeks at a time in my backyard. So like many other backyard observers I have been trying to brainstorm ideas for a cheap-easy semi-permanent cover for my SCT. I know there are many available “systems” out there (Desert Storm covers, industrial strength 55 gallon poly bags liners, etc.) some of which I’ve actually tried, But short of a roll-off shed of some kind they just don’t provide enough long term unattended protection.
My requirements are as follow:
Non-permanent (no covenant boards or permits or complains from my wife)
Good weathering resistance (Sun/UV resistance, waterproof sealing, not affected by high winds).
Some kind of hard material (it hails here in Colorado in the Denver area on very short notice).
A good thermal “R” value to keep the OTA temperature equalized during the day/night cycle.
Has the potential to put some kind of active cooling (Pettier (sp?) junction) in place later.
System can be adapted for either a tripod or more permanent mounting system.
One idea I’ve come up with is to buy two relatively cheap camping coolers to join together. This would be done in a top-to-top manner discarding the original hinged top doors and having the top cooler upside down to make a larger two-piece shell.
These coolers are rugged (covered inside and out with tough plastic with dense foam in between), can be made both weather and thermally air tight, and are cheap. The only major issue is joining the two coolers together with some kind of sealing lip/gasket and latching arrangements so that it is water-proof and figuring out how to adapt the bottom cooler to sit on the peer/tripod and fit/clamp tightly in place but still come off easily when it was time to observe. If at a later time this idea works well I can figure out how to install an active cooler system to bring the OTA to night temperatures 3 or 4 hours before the sun actually sets and have it thermally “equalized” (cooled down) and ready to go that much sooner.
BTW – I got this idea from watching a nature program with two professional photographers going out in the wild for 6 months. No fancy-dancy pocket-laden signature photo bags or expensive aluminum gear boxes in sight. All of their (very expensive) equipment was well wrapped in thick foam sheeting and stored in garden variety picnic coolers with some straps and locks installed for the top doors. I figured they may know something I don’t . . . or maybe they were just being cheap
. But with equipment costing into 6 figures and their livelihood on the line in remote places the system must have some merits.
Any comments?? If there is interest I can try to put any results I get here on AM.
Tom Mengel
Moderator Equipment Talk
“Insanity: Trying the same thing over and over and expecting different results”.
Albert Einstein
