John Greenlee
Before and after
Power Supply
Started by bkovacs, 08/13/2005 04:17AM
Posted 08/13/2005 04:17AM Opening Post
When I got my Celestron 9.25 AS-GT I also bought a Power Tank from Celestron 7AH model. Little did I know that I would also be getting a Dew Buster and Heat strips for my optical tube corrector and eyepiece. I got two Dew-Nots. Here in Pennsylvania dew is a problem in Spring and Summer. Now I need to get another power supply to power the heaters. What would all recommend. I seen a 12AH power supply at Sears made by Schumacher. They also have a 17AH model for more money. I already have the Celestron Power Tank to power my scope. But what would I need power wise to power the heaters. The ones at Sears only have one recepticle for a cigarette lighter adapter. So I would be able to use my Dew Buster and nothing more. Not that I need anything else. smile
Posted 08/13/2005 05:12AM #1
Buy a deep cycle battery with a carry strap from Walmart for about $35 and you will have enough power to run everything. You can get a double cigarette lighter socket and just put alligator clips on the end that would normally go in the lighter. I see these all the time at $.99 stores. Alligator clips are $2-3 each and you are set with 35-40 amp hours of power.
