Powermate v. Barlow
Started by cbator, 12/04/2003 07:32PM
Posted 12/04/2003 07:32PM Opening Post
I have a Celestron Ultima Barlow and was wondering if a TeleVue Powermate would show significant improvement. I use it on 24mm and higher power eyepieces. Thanks.
Posted 12/04/2003 07:40PM #1
I honestly cannot tell you firsthand but several of my friends have used my 2.5 Powermate and compared with Daiken and Meade barlows and they all said the Powermate always gave superior views. Most recent was at Chiefland on Saturn using a TEC 140 and a Meade 12" SCT. The seeing was excellent several nights in a row and some rather stupid magnifications were being touted. I saw it a about 350x in the 12" and the images were VERY nice.
Walt
Posted 12/04/2003 09:21PM #2
David Knisely wrote an excellent review of the 2.5x Powermate published on Cloudy Nights Reviews. the Powermate won hands down up against a meade 140 and david explains all the reasons why.
edz
Posted 12/04/2003 09:35PM #3
I have both -- an Ultima and a 2.5X Powermate. I've had the Ultima for almost nine years, and the Powermate for almost four.
I have not discerned a significant difference at the eyepiece. Each does a very good job.
The Powermate is a better choice for imaging &/or astrophotography.
The Ultima is more versatile with regard to magnification factor. Longer working distance between eyepiece and Ultima yields greater magnification. The 2.5X Powermate doesn't behave in that manner (it's not a Barlow).
Best wishes and luck.
-Dan
Posted 12/04/2003 10:44PM #4
No. For 24mm and shorter eyepieces I don't think
the difference is worth it.
Posted 12/05/2003 04:07AM #5
For visual use at least, the main benefit is with long focal length EP's (the inspiration for the Powermate was the 'Panoptic Interface' to use when barlowing the 2inch Panoptics; I believe the powermate is essentially a barlow + interface in a single package).
I've had a Meade short barlow (not so great), a Meade #140 Barlow (much better), and now use a 2.5x Powermate. The PM outperforms the Meade 140 barlow by a noticeable but not huge margin, even though I don't use long f.l. ep's with it. The Ultima, however, is reportedly an even better unit than the Meade, so I assume the difference between the Ultima and a Powermate with mid-to-short f.l. ep's is going to be awfully slight.
Posted 12/05/2003 02:24PM #6
The powermate is not a barlow, it is telecentric, meaning that it does not move the eye relief position nor reduce the field stop of plossl eyepieces. It only amplifies the image size. An ordinary barlow will increase the eye relief of an eyepiece, which may be good (8mm TV plossl) or bad (32 TV plossl).
