A couple of weeks ago I had posted for collimation help on a truss dob( http://www.astromart.com/forums/viewpost.asp?forum_post_id=356207&poll_id=&news_id=&page=4 ). The general consensus was weak truss tubes / pole flex.
I've now upgraded to 1.125" diameter, .059" wall poles (as large as the scope will take) from 1.000" diameter, .055 wall. And now the oddest thing is occurring; from approximately 50 degrees vertical to 90 degrees (completely vertical) there is still a collimation shift of about 0.5". (Check out the video's on the prior post to see what I'm talking about). Conversely, from 50 degrees to 0 degrees (horizontal) there is no measurable shift at all, so the stiffer poles have made quite a difference here.
Can anyone help me with why now my problem is only from 50 degrees and up? Here's what's been eliminated so far:
1. It's not the primary; a piece of tape had been laid on top of the mirror box. The laser still moved. (See prior post)
2. All tightening points are tight to overly tight.
3. The collimator is a perfect fit in the focuser and isn't tightened (I've tightened it to check, and the same thing happens.)
