I just purchased a very low usage Celestron Ultima 8. Its an unusal example because it was originally sold by Orion Telescopes so the tube is white not black, grey, or orange.
Anyway, this thing is huge! I told my wife "it fits in its own suitcase honey, it won't take up much room at all"....
I've assembed the telescope and am having a problem with its "Right Ascention" drive. I can't move the telescope from side to side with the hand controller. When I press the buttons to skew the scope I hear the motor working but the scope doesn't move.
The declanation motor and the motor focuser motors work as expected.
I belive this is probably why the original owner sold it to me...This was purchased at a VERY good price and the optics are flawless-the whole scope looks almost new.
I opened up the drive base and the worm gear doesn't appear to turn when the scope is skewing like it should. It almost looks like there is a belt connecting the motor to the worm gear shaft?
The electronics look ok, which is a relief because they would be hard to replace. Has anyone had a similar problem with a C-8 of that vintage? How would you remove the worm gear mechanism to check out the motor and the gearing? (I see two stainless steel screws holding the whole assemly to the base but when they are removed nothing budges).
There are two options for powering this scope, a 9V battery or a 12 V external (by using a jack) power source. Could my problem be that I am only using the 9V source?
