Ruben Tommasi
Andromeda Galaxy (M31)
Questions about eyepiece case
Started by usal1685, 02/25/2004 01:15AM
Posted 02/25/2004 01:15AM Opening Post
Hi,
I have an off the wall question that no one I have talked to really can answer...
I bought an aluminum style case from a local hardware store on sale. It has the typical look of the foam cases that are sold though meade, celestron, and orion and the foam inside is totally adjustable to fit anything you want in there. But here's my dilemma.....The case has a funky plasticy smell. Hard to explain the smell, but I know it came from the process that made the foam. So is that harmfull to my eyepicese?????
Are there special foams that should only be used with telescopic gear? Or is that just a property of the foam and I'm over reacting?
I'm experimenting with the case right now using a ordinary mirror and looking for any film. But if anyone has any info I would be more than grateful. I love my eyepieces and want them safe.
Thanks
Jay
Posted 02/25/2004 01:42AM #1
Jay,
I've used one of those same cases for years and have not experienced any problems. If you have any fear you can remove the pieces and let them air out before using for your eyepieces.
The gases, if any, released aren't caustic to glass, but may cause 'filming' on exposed glass surfaces. Most people leave top and bottom caps on their eyepieces, filters, etc anyway so exposure would only be during removal. Eyepieces should be cleaned regularly anyway as you'll have more problems with fingerprints, eyelashes, dandruff, dirt, moisture, etc than from any problem with gases. Also, don't leave the case in direct sunlight or high temperature areas for prolonged storage. It is at these higher temperature points which 'gassing' is more likely to occur. Also, as a sidenote you can put a couple of packs of dessicant in the case to take care of moisture left inside closed case after a night's observing.
If you are really concerned I would suggest looking for a scientific supply house which deals with special foams. Also, consider using the new plastic cases which encase the whole eyepiece. These will be helpful.
Posted 02/25/2004 02:02AM #2
Outgassing can cause an oily film to form on everything. You could put the foam out in the sun (SUN, what SUN?) and it should stop producing the gasses. I use military spec non-gassing foam for my cases, but it is not cheap!
This is the foam in two of my 3 cases. The case on the right is a bit more full now! ;^)
Floyd
fblue's attachment for post 76745
