Re: C9.25 Dual Axis Drive/Polar Alignment Problem?
Started by Santeh, 10/05/2003 01:53PM
Posted 10/05/2003 01:53PM Opening Post
Hi!
Last night I had a chance to attend a star watching party and took my C9.25. I was excited as I recently installed dual axis drives to my stck CG5 mount head, as well as just finished fitting a Pelican 1660 case for my OTA (I succeeded in getting everything but my mount head, tripod, and eyepiece collection inside the 1660. As such I got a lot in the case, and was very happy).
At the star watching there were 3 dobs (looked like two 8" and one 17"(?)) and my telescope. Due to the time of setting up for the star watching I could not see Polaris, as such I had to approximate where it was. As it turned out I was close but not perfect in my estimation.
When using the system with the new dual axis drives I noticed the RA on the dual axis drives slewed very quickly and I could keep up with the fast movement of the moon, etc.. Yet the DEC could not keep up. In the end I would always loose the celestial body I was looking at very quickly. In fact even with a 25X eyepiece the moon would only stay in the FOV for around 30 seconds and then I would have to reposition the telescope.
This was exasperating to say the least, especially since the 8" dobsonian would keep an image of Mars in its FOV for a long time, whereas my telescope could not (I could barely center it as it would leave too fast).
Any thoughts? Is the fact I could not get a really good polar alignment the problem I was experiencing? Is the dual axis drive system not working (I tend to think this may be the case since I could not get the slewing to work for the DEC nearly as fast as the RA)? Do I need a better mount than the CG5 (I had also included legs stabilizers), such as a Losmandy GM8?
Thanks you all in advance!
Sam
Posted 10/05/2003 08:15PM #1
Normally, if you are reasonably polar aligned, you should not have to move the scope in declination to track an object - with the RA motor running, the scope should track reasonably well without human intervention.
>>moon
Do you mean you were using the hand controller to track the moon 'manually'? That should not be necessary, it should be automatic.
Are the DEC and RA motors plugged into the correct sockets on the controller? I can see how that would cause a problem.
