Yue Ma
HFG-1
Re: HELP with backfocus
Started by mhosea, 09/20/2002 05:38AM
Posted 09/20/2002 05:38AM Opening Post
Rob,
You have some choices.
1) Use eyepieces that require less back focus.
2) If you're close (doesn't sound like it, but if so) you can sometimes create a little back focus by moving the mirror cell forward on its collimation bolts (put them all as far forward as they can go and then back off a little for adjustment purposes).
3) If it's a tube scope, you should be able to mount the mirror cell a little closer to the secondary by drilling new holes and moving the cell. If it's a truss scope, you might be able to shorten the truss poles. (I haven't seen how they attach, so seek advice on this.)
4) A different focuser might provide more back focus (as you mention).
5) If a tube scope, the focuser and secondary may be moved closer to the primary (but you almost surely won't want to mess with all that--it's more a theoretical possibility than anything).
Maybe there are other options, but that's all I can think of that seems reasonable at the moment.
Mike
