"I am seriously debating purchasing a binoviewer and am wondering how much wider a feild of view I can actually get with it?"
The best you can do is equal the current FOV. A binoviewer will not increase your FOV and in some cases (when a corrector is required to reach focus as in a refractor or newt) it decreases it.
"can I get a binoviewer for $100? or is this a pipe dream."
You can get one for $200 with a pair of EP's from Burgess Optical, but you won't see much with it until you add a corrector to it, which can add anywhere from $20 to $500 depending on what you are looking for. For widefield, you'll need to spend at least another $130 for a low power corrector (1.3x) and that will decrease your TFOV by about 23%.
Also, those $200 binoviewers will completely vignette any ep with a field stop larger than 18mm or so. That's about a 23mm plossl. Your 32mm plossls will have about a 35 deg AFOV in the BB's.
Plan to spend more if you want to keep those low power wide field views.
The binoviewer forum might be a better spot for this.
Tom
Tom
