Sandy:
Here is my thinking, having owned similar scopes...
1. Money has to be relevent, otherwise, you would just replace the mount, the eyepieces and the scope itself....
2. The mount has wooden legs, better IMHO than the modern extruded aluminum legs. Probably adequate for wide field views.
3. Normally the 60mm F11 objectives are pretty decent on these scopes.
4. The finder is pretty flaky. The cheap solution is to just remove the optics and use it as a sight tube. The expensive option is to replace the finder with either a red dot or a 6x30.
5. Eyepieces, a Hybrid diagonal will be allow the use of 1.25 inch eyepieces. Add a Hybrid diagonal and some eyepieces and the scope will be actually quite nice...
On the practical side, reality speaking...
If you do/did end up with the 4.5inch Short Tube Newtonian and if it is anywhere near as bad as the 6 inch I tested from the same source, then you will have an extra mount, a couple of decent eyepieces as well as a finder.
I think the mount would handle the Jason rather easily, though rings would need to be bought. The eyepieces are normally actually not so bad and the finder much better than the 5x24 that comes on the Jason....
So, my suggestion is wait and see what you get...
