Horsehead Nebula
?? re: optical performance given a certain configu
Started by Rich Michal, 06/25/2007 08:04PM
Posted 06/25/2007 08:04PM Opening Post
Gang: I know this is a real elementary question but here goes anyway-when a manufacturer gives a set of optical performance specs for a particualr set up: do they routinely take into account say if there is a central obstruction or not? here is an example: Compare the limiting visual magnitude as well as teh resolving power of say an 8" S-C with central obstruction VERSUS say an 8" refractor with no central obstruction---
THanks ahead! Rich M
Posted 06/26/2007 02:12PM #1
IME, Not normally. Limiting visual magnitude is highly dependent upon the observer as well as the conditions, a 30% difference in light through-put results is 0.3 magnitude difference at best, not a great deal.
As far as resolution goes, to a first order, resolution only depends on aperture, given equal quality optics, a 8 inch SCT and a 8 inch refractor "should" split the same double. It normally doesn't work out quite that way.
