Now, I have tried to duplicate the test as you performed it Roland. The camera was held 3' above the EPs and a bit of telephoto was used to bring them in close so that they could be easily seen.
I also took four shots while walking around the EPs at 90° apart.
Same EPs were used, but this time I did not change the sequence in placement.
Many of the same statements hold true in this series. including red color the Pentax.
Now the field stops can be seen in the UWA, Pentax, Radian and Nagler, but they do not look like bright circles, but rather you are seeing them through the exit lens.
The sky can be seen reflection back from all the EPs with the XL just showing red rather than the blue and white colors of the sky.
Do note that the reflections do change as I rotate around the group in the four photos. This is what I was saying earlier about the position relative to the camera lens effecting the reflection.
However each of the EP was put into four different positions, so hopefully this is a fair test.
SO, what do you think about the results of the test. Does this look like I followed the process properly and got the shot you wanted?
I would have liked to have had other types to check as well, but I only have some not so good Plossls to add to the batch.
How would you all rate the EPs in this test, which is best?
Floyd
Floyd
