WR 134
Re: where do the go-to's go to?
Started by DuckView, 07/03/2007 06:45PM
Posted 07/03/2007 06:45PM | Edited 07/03/2007 06:47PM Opening Post
I own an LXD75 mount. I was cursing it when it was new, as it had the commonly bent encoder wheels and would not function in GoTo mode. I eventually got it back from Meade and it has worked since, except for the common glitches like keep it out of very cold weather or keep the computerized hand controller warm. I commonly hit most targets at 200X, and that's pretty good GoTo performance for the price. There is an aftermarket for supplying the mount with better bolts, cables and accessories, so you can fix it up with no problem. It handles any scope up to an 8" Newtonian or 6" refractor. It uses Atlas or CG5 counterweights, which are dirt cheap.
What I found was that the polar alignment scope itself needed aligning after it got back from Meade. After that, the optical axis of the OTA must be centered. If the mount is accurate with a Mak or refractor that typically has the optical axis in line with the tube axis, then the mount is doing its job. The SN8 OTA was badly miscollimated on arrival, and when I got the optical axis in line with the polar axis of the mount, then everything was accurate in GoTo mode except the occasionally missed planet which is hard to compute but easy to find visually. The fact that the mount can compensate for huge errors in setup alignment was demonstrated by the fact that when I moved to Montana, I still had the controller set for Arkansas, and targets were in the field of view at 200X, many of them almost dead center. I think the location info mainly determines rise and set times for objects. Objects do not move in relation to Polaris and alignment stars due to a geographical shift, but they may or may not be visible in both places at once.
The reason you may find few of these mounts for sale used relative to new sales, is that when the technical bugs and learning curves are brought under control, there is no reason to move on to something like a GM8 at a much higher price that does hardly anything more but lighten your wallet (except maybe for photography). Most people are not into high end astrophotography, and the mounts work OK for visual work where you are typically limited to 200X mags by seeing conditions. If you need a part, you can usually find it at LXD55.com, and it will be an upgrade over the Meade part. I'm not afraid to work on my LXD75 mount, as it is cheap and not worth sending off anyway when out of warranty. My LXD75 holds a 6" Mak-Cass steady at 350X mag, and that's good enough for me. If I need a steadier mount due to wind, I can use my standard Atlas mount, and since I paid $750 new for it, I am still well under the cost of a standard GM8 that has no GoTo, and I have two mounts I can use simultaneously if I want.
The LXD75 and Celestron CG5 mounts are worth far more than the one-armed Nexstar mounts as they are universal in mounting capability with just about any OTA you acquire up to 8". You often find them for sale where a person bought the outfit with the intention of selling the mount, because you often get the outfit for only a couple hundred bucks more than the bare OTA. Doesn't make sense, but that's how Meade and Celestron market them. In effect, you will save about $200-$300 over buying the OTA outright after you sell the mount, and have some accessories as extras.
I think a GoTo mount is pretty useless for lunar/planetary/double-star service as you just swing over to the target and start observing. I'll just turn on the laser on the Mak and slew to the target without bothering to enter anything in the computer. However, for dim objects in deep sky when I have the Schmidt-Newt mounted, it comes in very handy and you will get a chance to look at many more targets in a night. I suspect that deep sky addicts love their GoTo mounts and are loathe to give them up.
The one armed mounts are limited in scope mounting capability, so very few people would buy an outfit with the intention of selling the mount. The LXD75 and CG5 on the other hand, have huge market appeal and most amateurs have an OTA that could be mounted on them. Unless you intend to use a scope terrestrially, it makes no sense to me to buy a fork or one-armed mount. Could I mount a TEC eyepiece turret on a fork mounted OTA, and would the OTA balance after I did so? Just one of several reasons that demand for a one-armed mount would be relatively low. They stay with the SCT they came with.
