Hello,
I'm feeling fairly frustrated. I'm in the process of rebuilding a 5" F15 refractor that I built up back in the mid 70s...Jaeger lens (and a good one at that!). I decided that my original large Unitron focuser was not up to the task anymore particularly since there was no way to secure heavy items in the draw tube attachment since there is no clamping mechanism, just slide in pressure. So I bought a really beautiful 2" focuser from Moonlite, that comes with a 1.25" adapter ring. Also have a 1.25" adapter ring from Williams Optics.
Problems start immediately when I have tried to use my 1.25" laser just to align the focuser with the center of the lens (never mind the cell alignment). The adapters fit so loosely into the 2" focuser that tightening the set screws, either to hold the adapter, or to tighten the 1.25" side around the laser, cause the alignment to the center spot to shift quite a lot from test to test. (The beam swings at least 3/8" around center.) I wrote to Ron Newman at Moonlite about this and got a swift response that "all" adapters are made to fit pretty loose, and that I ought to use a 2" laser with no adapter to align. Fine, I can accept that as reality, but why bother? It just means that anytime I would use any equipment, in any adapter...even a precision Williams 2" diagonal, or a 1.25" binoviewer, camera, I might as well have not bothered with the alignment! Most all of my equipment is 1.25" What does a person do here? I've thought of going to a machine shop and having a "tight" fitting 2" to 1.25" adapter made; at least if I had that adapter, and aligned with it, I could be sure of keeping some alignment. Or am I being overly fussy here? How do you all deal with this issue?
Sorry if this is old material...I'm kind of new here.
