I recently bought a used dob. The secondary has a heater wired in it. Coming out of the secondary housing is a wire with a transistor on it that I assume is a temperature sensor or something, an LED, and power wires that terminate in a 9V battery type connector.
Any thoughts as to the proper voltage for this? E.g., can I connect to it using another 9V-type connector but use my standard 12v supply battery or do I need to step down the 12v to 9v for this? (I don't want to burn it out by accident).
Thanks.
- Mitch
Thanks.
- Mitch
