Well, I have begun to make the brackets and fittings for the ServoCat installation. The Starmaster side bearings are only 3/ 4" thick, so I had to make an aluminum bracket for the Alt drive cable tensioner lever. It needed a 1" wide mounting surface. So, I made one from 1/4" thick 90 degree angle aluminum stock. I think it will work out quite nice. I am also making some stainless guides for the cable that will give something for the cable to set on where it goes over the edge of the side bearing. I did not like the cable just setting there on a sharp edge. Cables are not meant to take that kind of bend. I can see that there will be a few things that will require some engineering innovation to make this work on this scope.
Next I am working on the podium for the Argo Navis. But I have to have a few things figured out before I can finalize that design.
The Argo Navis looks so cool, but is so big compared to the Sky Commander. I do like the controls though. Nice layout and design on this computer. 29,000 object data base should be different. I am sure there will be a learning curve on this one. I may play with it as a DSC before the Go-To is installed so I can get used to it.
