I was asked by someone to take a picture of the counter balance set-up that I use on the NS8GPS. They wanted to know how where to put the sliding weight to balance the scope with a particular EP without releasing the clutch and checking balance.
I did the weight and balance for each EPs with the clutch released then marked the slide. After I found the range of movement for each I found that several EPs weights were about the same and I was able to just have a stop for a certain range of EPs. Note that the arrows point to the position for the front of the slide. In the case of this picture it is set for the 12-17mm Nagler EPs.
I hope that some may find this useful. It saves me a lot of time and I know the scope is balance when I put the EP in place.
Floyd
Floyd
