Hi Guys, I bought an ST-4 a bit ago. Never used it and honestly don't know how. I was wondering what the difference is between an auto guider and an imager? Does an auto guider take images or is just for guiding a scope while an image is being taken by another camera? Thanks, Joe
ST-4 Autoguider
Started by jserio, 12/30/2014 11:50PM
Posted 12/30/2014 11:50PM
Opening Post
Posted 12/31/2014 04:59AM
#1
Hi Joe, The ST4 was (and IS) an absolutely WONDERFUL auto-guider. Requires no PC, completely self-contained. But to adapt it to your guide scope (or off-axis as I did) requires a little practice and know-how: The CCD chip is TINY by today's standards, so you need to pre-select your guide star with either a surrogate parfocal eyepiece or equivalent flip-mirror. And when you insert the guide head need to (roughly) clock it to the RA/DEC directions. The beauty is the "calibrate" set up. You just hit that (per directions) and it will calibrate itself, sensing the directions and magnitudes of +/- Dec and +/- RA. It will say it's happy and you then just hit "track" and it locks onto your guide star like a bulldog. You also need to know some basic electronics: The ouptputs are DPDT solenoids and I think NO/NC contacts which you wire up depending on how your scope is set up. I amended a cheap Edmunds geared-down 12V reversible DC motor to my homebuilt DEC tangent arm and a commercial frequency controller to my RA (Byers 11 3/8). After some fiddling - it was tracking my 650-lb newtonian flawlessly for many thousands of hours of use at 2000mm EFL. All that said - you of course need a decent mount with good, smooth, reliable drives and decent polar alignment. I consequently collected hundreds of multi-hour exposures on film (yeah-way back then) with sub arc-sec tracking better than I could do "by hand" and I was in bed sleeping! All that said, i believe there are mounts and "idiot-proof" plug 'n play guiders today that would be WAY easier to use but maybe quite pricey once you get everything you would need. I'm old-fashioned (and now just plain OLD) so still prefer to build my own stuff and understand how and why it all works...or doesn't. I recently got a fine 36-inch PM that will fit in my dome!...ALL I need do is build the scope - Yikes! It will replace my very nice little 29-incher... The ST-4 can indeed collect images...but was never really meant for that because the chip is miniscule. Tom Dey
29-inch Dob in a dome
36-inch upgrade soon
LUNT 80/80 solar scope
FLI 6803 cam
APM 100mm APO Binos
JMI RB-16 Night Vision Binos
Zeiss 20x60 IS binos
Posted 12/31/2014 03:55PM
#2
Hi Joe,
I have an ST-4 and still use it as an autoguider with my DSLR. As others have said, the chip is quite small, but it does work great.
You can use the ST-4 for imaging, I started my CCD imaging this way. But there are 2 problems. Firstly is the small chip. This means it works best on small objects such as galaxies. The second is that it is only an 8-bit chip, and so will not show as much as more modern and more sensitive chips.
When using the ST-4 as an imager, you will need to connect it to a computer. you will also need software to control it. SBIG does have software as a free download for the ST-4 on their website. You can use either the dedicated ST-4 software (although this is DOS!!) or I think that CCDOps is available as a free download.
One warning though.... once you start CCD imaging, you will quickly become hooked and want bigger and better CCD's!!!
Hope this helps.
Maurice
Hope this helps.
Maurice
Funding Member
