TMB monocentrics vs. UO orthos
Started by Inge_S, 12/30/2003 08:56AM
Posted 12/30/2003 08:56AM Opening Post
Anthony Allsobrook kindly lent me three TMB monocentrics for testing. Yesterday night I had the chance to try them out, and compare them with my own UO orthos. The following focal lengths were available:
TMB's (6mm, 8mm, 10mm)
UO's (5mm, 7mm)
I tried the eyepieces on Saturn as well as various double stars, NGC2392 (Eskimo nebula), M51 and M81/82. Sometimes the 2.8x Klee barlow was used in combination with the eyepieces.
The most obvious difference between the eyepieces is the field of view. The 30 degree field of the TMB monos really looks small compared with modern eyepieces. However, I found the narrow f.o.v. somehow appealing. Maybe there is a nostalgic or sentimental reason for this, but I would recommend anyone who gets the chance to observe M82 through a TMB mono. With my 8" f/6 in combination with the 6mm, the galaxy traversed almost the whole field. This made the galaxy look very large and impressive. The obscuring clouds of the galaxy were quite prominent - very nice.
M51 was also very nice with the same eyepiece. The spiral structure is not easy to see in an 8-inch, but it is definitely there. Like M82, the M51/NGC5195 pair nearly filled the field of view, and the image contrast was excellent.
On double stars I found the difference between the TMB's and the UO orthos to be marginal. Depending on the separation, the optimum magnification could be anything in the 120 - 240x range, and the eyepiece giving the best magnification also gave the best impression.
On Saturn the TMB's and the UO's performed equally well. My general impression is that the resolution and light throughput of the TMB's are equal or just a shade better than the UO orthos.
I had no problem combining the 8mm monocentric with the 2.8x Klee. At a magnification of 420x and a real field of view of 4.3' one might expect that it would be difficult to keep an object within the field of view using a Portaball, but I found it reasonably easy.
I like the TMB's, and will definitely acquire at least one or two of them. Not only for observing planets and double stars, but also for scutinising small DSO's.
Posted 12/30/2003 02:01PM #1
I currently have the TMB monos (4-6-8) and have had the UO orthos (4-7-12.5-18) in the past. The primary difference I've noticed (besides FOV) is the monos produce slightly brighter images and much higher contrast on planets through a 5" APO. They also work well with a C9.25 but I never used the UO orthos through this scope to compare. Haven't observed any double-stars with them yet. Looking forward to the TMB 1.8X barlow next month.
Rob
Posted 12/30/2003 04:14PM #2
You might want to give the TMB's a spin on old luna.
Tom T.
