Tripod Carrying Capacity for Astrophotography
Started by pmlogg, 06/05/2009 11:55PM
Posted 06/05/2009 11:55PM Opening Post
Following many glowing comments on Berlebach tripods and adverse comments on the Losmandy GM-8 tripod I managed to pick up a used UNI 5. This is an older model but is rated for up to 132 lb., which is as much as for any of their models other than the very top ones such as the Planet. I've added one of the Berlebach trays which is supposed to further stiffen it up.
My question is what a realistic maximum all-up weight should be to put on such a tripod when using it for astrophotography (assuming not constrained by the mount)? Do I need to reduce from the 132 lb., as I would expect from the mount's maximum carrying capacity or could I load it up to the limit without degrading performance?
Posted 06/06/2009 01:15PM #1
Just what are you planning to put up on that tripod that weighs 132 pounds. The GM-8 plus its maximum weight carrying capacity has to be less than, what--50 or 60 pounds?
