TV 40mm Wide Field
Started by aaronsland, 10/11/2003 11:38PM
Posted 10/11/2003 11:38PM Opening Post
Does anyone know the specifications of this eyepiece? It is marked as made in Japan. I don't find anything on the TV website.
Nothing in education is so astonishing as the amount of ignorance it accumulates in the form of inert facts.
Posted 10/12/2003 12:06AM #1
I believe all of the Televue Wide Fields were 65 degree apparent FOV.Eye relief was quite large on the 40 probably 20+.One huge chunk of glass the weight was over 2 pounds.Great eyepiece it was discontinued with the introduction of the Panoptics.
Posted 10/13/2003 02:04AM #2
The Widefield line was discontinued almost 10 years ago. The Panoptic design enjoys a slight advantage (+3 degrees) in apparent field, as well as significant advantages in both eye relief and extreme off-axis fidelity with faster scopes. As Victor noted, the Widefield's apparent field spans 65 degrees. The design produces eye relief right at ~60% of inherent focal length. (The Panoptic: ~70%.) The 40mm Widefield's eye relief is ~24mm. The design includes 5 elements in 4 groups. Here's a general description of the design's layout/sequence:
field lens: double convex singlet
interior field lens: double convex singlet (diff. radii)
interior eyelens: plano-convex singlet
eyelens group: double-convex/double-concave achromat
Excellent eyepiece. You have a keeper.
Best wishes.
