Wizard Nebula
ultima 8 PEC - weak drive or user?
Started by rajuncajun5544, 10/11/2009 08:16PM
Posted 10/11/2009 08:16PM Opening Post
HI,
Any reason an ultima 8 PEC base would only track when the OTA was weighter pretty heavily to the east? Is this normal? The drive won't even rotate the forks when it's balanced totally neutral. I'm running on a fresh 9V battery.
Could the gears be binding somehow? How does the worm-gear mesh adjustment work and should I mess with it? I really expected for all the cult status this drive base has for it to be less feable. It's pretty much unusable as-is since I'd have to get a huge counter weight to stay east-heavy all the time.
Perhaps I'm doing something wrong here...but the single spur gear non-byers mount I traded up from was stronger than this.
Thanks!
Posted 10/11/2009 08:17PM #1
Whoops - I said weighted to the east, I meant west as in pulling the scope in the direction the drive should be going. It only tracks when balanced heavier that way.
Posted 10/13/2009 01:46AM #2
Andrew:
I have a similar scope to yours. Here is the thread that may answer some of your questions: http://www.astromart.com/forums/viewpost.asp?forum_post_id=680324&poll_id=&news_id=&page=3
