Hello:
I was recently star testing a pair of 20" f/4 mirrors. I used ronchi grating (with barlow) and a 9mm MA eyepiece from Meade, simply because it's the shortest focal length decent eyepiece I have. For both mirrors, the secondary mirror shadow seemed larger and darker inside of focus, and smaller and harder to see outside of focus. This difference was only apparent very close to focus, when I could see perhaps 3 or 4 of the rings on either side of focus. As such, the two mirrors seem a bit under-corrected. The "mirror cells" (a simple plank of wood) may be a contributing factor, as I also saw astigmatism and trefoil that changed between targets.
However, a friend of mine told me that he heard that certain eyepiece designs can show what looks like under-correction in a star test. Given that I used a simple/cheap eyepiece on an f/4 mirror, I wouldn't be surprised if this was the case. My questions are:
1) Can an eyepiece make an otherwise good mirror look a bit under-corrected? Can adding a barlow (thus delivering an f/8 beam to the eyepiece rather than f/4) change things?
2) If so, what eyepiece designs are best for star testing fast mirrors?
Cheers
Mike Connelley
Cheers
Mike Connelley
