I would like to get some opinions on my situation. I have been using an 8" Celestron SCT on a CG-5 mount for almost three years and have wanted to upgrade for a long time. I recently saw the clearance prices on Orion and impulse purchased the GP-DX for $999, and am now at the point of deciding whether I did the right thing or should return and get something else instead.
After a LOT of reading on the web, I believe I have made the right choice, but would like to hear from those who have used both the GP-DX and GM-8 (not the smaller standard GP vs the huge G-11). Once I add the motors, the price of the two will be identical.
My needs:
- mostly for C8 but also for TV85
- high power (up to 500x) tracking for lunar/planetary
- light weight so I don't think twice about 4am lifting
- easily transportable to dark site in car
GP-DX pros:
- I have confirmed it meets my needs (stable at 500x)
- much lighter (18.7# vs 29# w/o counterweight)
- less bulky shape and size for transport
Losmandy pros:
- porter slip ring clutch system (pro and con...see below)
- "advertised" as supporting more weight
- anything else I'm missing?
As I don't have a GM8 to play with, I'm not even sure of it's pros. For example, a lot of people seem to like the clutch system, but I have found that my use of the C8 with binoviewer requires frequent rebalancing when moving across the sky (turning the tall binoviewer shifts weight center on BOTH axes), and the GP-DX flip-clutches are fast to release for this purpose. I have the feeling this frequent rebalancing would take longer with the Losmandy clutches but just can't experiment.
Also I can't tell if the GM-8 can indeed handle more weight than the GP-DX. Everything I've read says both handle a C8 for photo/visual, a C9.25 visual-only, and not a C11. Is this correct? If so, then they must handle the same weight, right?
The Tak EM2 also looks really nice and meets my needs but would set me back a few hundred dollars more... I would also like to hear from anyone that could think of a good reason I should get this over the GP-DX. (it seems the design goals for GPDX & EM2 were the same, the only difference being that Takahashi relaxed the cost constraint)
Thanks for any help,
Bruce.
My needs:
GP-DX pros:
Losmandy pros:
Bruce.
