What are "phase coated" binoculars?
Started by ddrake, 09/05/2003 06:41PM
Posted 09/05/2003 06:41PM Opening Post
Orion is advertising these and I'm wondering if there is anything to this phase coated technology. Is there a real improvement in image contrast to non-phase coated binos? Thanks
Posted 09/06/2003 01:08PM #1
An easy demonstration of effective phase cancellation can be observed on the surface of a soap bubble. The film thickness will vary and as the bubble thins from evaporation you will see areas that have no reflectance at all. These are perfect zones of cancellation and you would think there are holes in the bubble.
Posted 09/08/2003 01:49PM #2
Phase coating are for Roof Prism binoculars and as I understand it are a real improvement. One of the German companies originated the technique and as i understand it patented the best technique so that until recently the others have been a bit behind.
My simple understanding of phase coatings is that unlike Porro Prisms, roof prisms essentially split each beam into two separate beams and erect the image and then reassemble the two sides. The problem with this is that each of the two paths can be out of phase with each other and this will degrade the image.
Bottomline is that my explanation maybe weak or even wrong, but Phase Coating roof prism binoculars does provide an improvement in sharpness.
jon
