I'm likely upgrading my SCT to a 16" f/10 Mak-Cass. I've got some questions about cooling such a beast.
It will be observatory mounted. The temp inside my observatory in the evening is typically 2 - 4°C warmer than the outside temp. Not a lot, but enough to see tube currents in my current SCT.
While the Mak has a considerably thicker corrector, my SCT will dew up in an hour or so (even with dew heaters) if I leave the dew shield off. So I think the corrector will probably lose heat to the sky plenty fast enough. I imagine the primary is the main concert. (But if you disagree, please speak up.)
For the primary, do I want to promote a laminar airflow all the way up the tube from the back (the tube is 20-1/2" in dia, and has pierced baffles, so I've plenty of room outside the light path), or would it be better to scrub the front of the mirror (fans from the side), and let the warmer air rise out of the tube on its own?
Thanks for any comments,
-- Jeff.
-- Jeff.
