A coupe of weeks ago I posted about having what appeared to be a problem with collimation after regluing my primary. I think Pat Plunkett hit the nail when he posted he had a similar experience and thought the primary was pinched.
Well I used a thin-bladed saw with sharp teeth and basically pushed through the silicon glue. I had not used a support such as nails to keep the mirror off the mirror cell and I believe the mirror was resting on the top of the collimation screws, or just about. There was certainly way to much glue used. I went overboard
For the second go around, I used three rather large nails - they cost about 9 cents a piece from Home Depot. They were about 6 inches long and maybe a 1/4 inch diameter. Beefy.
I used standard silicon caulk by GE and made three small mounds, taller than wide. I sat the mirror down and the mirror came to rest on the nails.
The mirror cell has three clips but they are more like posts that stick up about 1 inch perpendicular to the mirror cell. There was about 1/4 inch of space between the posts and the mirror. I filled those spaces with silicon.
After drying I noticed the mirror had just a slight bit of spring when I pushed down on it. I think this may compensate if the cell warps a little when tightening the collimation screws.
I reattached the mirror cell tonite and did a quick collimation and the difference was 100% better. Even with rough collimation, the stars were just about tack sharp. I've only seen it better once or twice and that was after some tweaking and good seeing. I'll get it on the money tomorrow nite.
So problem solved and lesson learned.
Thanks to all who contributed.
Sincerely,
David Roberts
Sincerely,
David Roberts
