Today I messed with collimating the laser again,(according to Floyds article) I did this yesterday and was so frustrated as I couldn't get repeated patterns. Today I made 8 marks around the barrel of the laser, set up a vise and used the top part of my barlow for a tube to hold the laser. I put a piece of paper on the wall about 20 feet away and carefully tuned the laser to each mark and marked a number on the paper to represent each number that it was turned to. The problem I believe is that the plastic barrel of the laser is not ROUND! It must be ever so slightly mis-shapen. Grrr. No wonder I'm always tweeking the alignment of the secondary!
Note the attatched picture. It shows the laser, the numbers I put on it, how I held it and the crazy pattern it makes when rotated. It should make a circular pattern. ( I was very careful also to tighten the set screw the same amount after each rotation.)
Do not ever buy a cheap laser!
Ron
Ron
