Ruben Tommasi
Andromeda Galaxy (M31)
Whatever happened to offsetting the diagonal??
Started by Tom Bourg, 07/26/2004 10:27PM
Posted 07/26/2004 10:27PM | Edited 07/26/2004 10:30PM Opening Post
Hello,
I've got a sct nowadays but I have to admit that Newtonians are my favorite scopes.
When I was a teenager 35+ years ago I remember that it was common practice to offset the diagonal (lower it if I remember correctly) on Newtonians so it was below the optical axis by a few mm. I believe this was done only on large scopes, which meant 10" and above back then
I even remember reading an article in Sky and Telescope about it and I believe the author included a chart for offsetting the diagonals for different sized primary mirrors and focal lengths.
But nowadays I see nothing about this even though the mirrors available to the public are much, much larger than those available back then.
Was this a bogus practice or perhaps it is not necessary with the faster systems in general use now?
Thanks. Good skies everyone.
Tom B.
Posted 07/26/2004 10:58PM #1
Hi Tom,
If you have a slightly larger than necessary diagonal you may be 'ok'. If you do a ray trace it is apparent that an offset is needed away from the focuser to catch the converging light cone.
The 45* flat is closer to the primary (up-stream, into a wider section of the light cone) at the 'away' end of the flat than the front. Without an offset, a portion of the cone is cut-off.
Clean skies!
John W.
