When to clean optics
Started by Lee Anderson, 06/13/2004 10:33PM
Posted 06/13/2004 10:33PM Opening Post
The other night, while shining a flash light into my C14, I noticed a film on
the main mirror that looked as though someone in the past had cleaned it and
left a residue. I don't think it effects the performance any, but it's hard
to say since it's probably been there all along. You can't see it under normal
conditions. Only, when shining a light down the tube. Should I attempt to clean
it or leave it alone? cwy
Posted 06/13/2004 11:10PM | Edited 06/13/2004 11:18PM #1
Leave it alone.
No mirror can pass the "flashlight down the tube" test - it is most unforgivable. Look at your mirror in daylight to determine if it should be cleaned.
Cleaning a mirror should be done sparingly, perhaps once every two or three years. There are many people who believe it should be cleaned less often. Part of it depends on your location. Does pollen build up on your mirror; does grunge somehow make it onto your mirror from frequent dewing (rare) or industrial pollution; have spiders found a new home on your mirror?
Aside from cleaning a mirror, I do rinse my mirror once each year. I first soak it in a tub with a mild soapy solution for a couple hours. Then, using a shower head with fine, high pressure spray, I pass the spraying showerhead about an inch off the surface of the mirror while it's under the water. I go over the surface (without touching the mirror of course) two or three times. That will release most dust and bits of whatever that my mirror has collected. I remove the mirror from the tub and rinse with 99% isopropol alchohol and let it rest for a few minutes and rinse again with distilled water (lots). I then use a bottle of compressed air (a no no for many people I know) and blow the water droplets off the mirror, so they don't dry and leave spots or streaks. I put the mirror back into the scope and nothing other than fluid has touched the mirror. It may still show a few small blotches, but nothing to make me touch the surface to overcome.
Gary Weber
Posted 06/13/2004 11:12PM #2
Lee,
I think all opticians will tell you never to judge the qwuality of the optics by shining a light down the tube at them. They will all look dirty. It is doubtful that this would ever effect the quality of observing or imaging the like.
Posted 06/14/2004 02:02PM #3
smile Thanks gentlemen. That makes sense, because the optics look just fine in normal daylight. I think I will just leave it alone as you suggest. Thanks again!
