Ghost of Cassiopeia
Your Newts and SCTs will be Obsolete!!
Started by yadda1, 12/11/2004 04:27AM
Posted 12/11/2004 04:27AM Opening Post
Ok, Maybe not anytime soon. But a company has come out with a "new design", a modified Gregorian Telescope that folds the light path and additional time for a super compact OTA. Wow!! Look out Celestron, Meade...?
Here's some info:
http://www.photonics.com/todaysheadlines/XQ/ASP/url.lookup/id.4748/QX/today.htm
http://www.fsona.com/
Looks like we'll have to look through the Army Surplus stores in the future.
Jerry Kuchera
Posted 12/11/2004 04:55AM #1
Here's a nice summary:
The most common are Cassegrain and Gregorian telescopes. The main difference between Cassegrain and Gregorian optical systems is that Gregorian telescopes employ a concave secondary mirror located beyond the focus of the primary mirror. This results in longer tube lengths, as the distance between mirrors is slightly more than the sum of their focal lengths, which is the reason Cassegrain systems are the most common. In addition, Gregorian telescopes produce an upright image, while Cassegrain telescopes produce an inverted image. FSONA is presenting a new compact optical system, which can be described as a modified Gregorian telescope. This telescope is ideally suited for free space optical communications but also has many other applications. The compact telescope is created from a standard Gregorian system by flipping the secondary mirror over a folding mirror installed approximately in the middle of the optical path between primary and secondary mirrors. In this manner, the primary mirror is constructed with a concentric "double curved" geometry, and a central obscuring folding mirror which matches the diameter of the smaller curve of the primary is mounted a short distance in front. This "double curved" geometry is easily produced using diamond turning technology, and the result is a compact telescope approximately 1/2 the length of a regular Gregorian telescope and roughly 2/3 the length of a Cassegrain telescope.There are several advantages to using this type of telescope:1. The system is very compact. Telescope can be as short as 1/7 of the focal length of the system.2. For Cassegrain and Gregorian systems it is very critical to keep tight tolerances on the centration between primary and secondary mirrors. The modified Gregorian telescope will always have perfect centration because both curved surfaces are machined at the same time on a diamond turning lathe. The folding mirror is flat so no centration is required3. The modified Gregorian system is inexpensive. Instead of two curved mirrors, there is one mirror with two curves, and one inexpensive flat folding mirror.4. The folding mirror can be used as a steering mirror for a tracking system.5. If the modified Gregorian telescope is constructed out of one material (ie. aluminum), it is completely a-thermal and insensitive to changes in temperataure.
Jerry
Posted 12/11/2004 04:16PM #2
There are no advantages of this design over more conventional systems that I can see except perhaps the very shortness of the assembly. However, are SCTs not short enough as it is?
Roland Christen
Posted 12/11/2004 08:02PM #3
Nonsense!
Darrell
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety."
Posted 12/12/2004 07:08PM #4
I saw the article about it in Photonics Spectra magazine.
It looks interesting, but that "mirror within a mirror" looks
complicated to fabricate (= expensive) so it will be interesting
to see which amateur telescope maker tackles one first.
Sure bet it won't be the manufacturers of current amateur telescopes.
"Pluto is not a planet"
-Neptune
