10 MM Ethos Report
Started by Rod Kaufman, 01/30/2010 05:53AM
Posted 01/30/2010 05:53AM | Edited 01/30/2010 05:55AM Opening Post
Well, I can see what Mike Hosea is talking about when he says if he's got 200 eyepieces he used and this is the one he would keep out of all of them and he'd be happy with it...
I took my 16" f4.5 dob outside of my home to look at the Mars opposition and despite the relative proximity of the full moon and poor conditions(2/5 seeing and light dew)I was thoroughly impressed with the performance of this eyepiece. Without a paracorr, you do see coma(as expected) at about 85% outwards around the periphery but given the size of the field, it's remarkably well controlled. With a paracorr the field is nearly aberration free and there's something in the instructions with the eyepiece about how to tune the Ethos with the paracorr beyond the 1 setting with some kind of adapter for NP refractor-like performance.
Mars was great during briefs moments of relatively decent seeing and I used my old generic O111 filter that bleeds red as a Mars filter and I could pick up delicate shadings and brightenings around the limb.
What floored me was how easy it was to see six stars in the trapezium with poor conditions and the full moon. I mean they were easily seen without averted vision and despite the full moon. I could even pick up five of them with the O111 filter which normally kills 'em.
The spacewalk effect: this is as good as it gets and it's as close to going into outer space as I'll likely ever come but looking at the Orion nebula, even under the poor conditions described above, was awesome. What a window into space.
This eyepiece is it for me.
Is it perfect? Nope. What's wrong? The rubber eyepiece extension cup is a joke. It behaves like a wet noodle and it peeled off in my hand as I raised it. Did I miss it? Not really but I could have used it given the full moon and the local street lighting.
I can't wait to get this baby under dark skies. It's going to be beyond awesome!
A truly superb eyepiece and worth every penney...
Posted 01/30/2010 09:23PM #1
See Rod, What did we tell you? Now you know what you were missing. Problem is, there are 5 more in the Ethos series. I have the 8mm and 13mm, but I am saving up for the 21mm once it is more readily available.
Clear, Dark and Steady Skies,
Spaced-Out Bob
Posted 02/01/2010 02:26AM #2
Glad you're happy with the EP--
I'm intrigued you mentioned using the OIII as a Mars filter. I have found my old Lumicon UHC works quite well on Mars.
Did you try barlowing the ethos? Even with the paracorr in, you'd only be at about 200X. Should barlow nicely, except for the mongo torque that results. (Although come to think of that, it's already a pretty ridiculous lever arm with the ethos in the paracorr...)
George Golitzin
