My new used 10mm XW came with an instruction sheet that explains that the inside of the barrel has had "matting" applied to enhance contrast... and that screwing in filters may remove "a small amount of paint".
I started to put a filter on during this morning viewing session-- then remember the caution. I tried putting the filter on the end of a T-adapter, an extension tube, and a polarizing filter holder, but none of them would work in bringing the eyepiece to focus.
So, what is one to do?
Should I ignore the caution and take my chances?
I've used filters with older XLs and when I checked today the insides are still grey and the area where the filter screws in looks similar to that further up the barrel. But the XW's inside is black not grea so it may using a different application.
P.S. I did have to laugh. Elsewhere in the sheet, under a bolded Warning it says
"Do not place the eyepiece under direct sunlight. (Doing so may cause fire)."
Hmm... is that the old magnifying glass effect? Is it the eyepiece or what's underneath it that will spontaneously combust? Is someone at Pentax playing mind games on us? Don't try this at home, folks!
