Iris Nebula
1.25" Low Power Eyepiece
Started by [email protected], 06/22/2006 03:05PM
Posted 06/22/2006 03:05PM Opening Post
I am looking for a low power/wide field eyepiece for my 6" f/8 Dynascope. I can't spend more than about $130 so I am looking at the following:
Meade Series 4000 40mm Super Plossl 1.25"
Stellarvue 1.25" 40mm FMC Plossl
Celestron Omni 40mm 1.25" Eyepiece
I welcome all opinions about which of the three is best. If there are any other suggested eyepieces, I'd like to hear about them also.
Tom
Posted 06/22/2006 03:17PM #1
Don't buy a 40mm Plossl. Get a 32mm instead. There is no real advantage to buying a 40mm Plossl vs. a 32mm in terms of true field of view - both will show the same amount of sky, it's just a little bit smaller in the 40mm.
Also, 40mm Plossls actually have too much eye relief for many people, making it a little tricky to place your eye.
Posted 06/22/2006 03:22PM #2
In the 1.25" format, the field of view that you can see is limited by the barrel of the eyepiece. Somewhere around 30-32mm is the maximum focal length needed to reach the limit. So a 40mm eyepiece will not show any more field than a 30-32mm eyepiece in the 1.25" size. To take advantage of the wider field the 40mm can cover, you need to go to the 2" format.
If you are stuck with the 1.25" size, you may find that you would like the higher power of the 32mm eyepiece over the 40mm.
clear skies,
dan
Posted 06/22/2006 03:44PM | Edited 06/22/2006 03:45PM #3
You guys are correct, after crunching some specs there is no practical difference in true FOV between the 32 and 40mm. Therefore it looks like I will set my sights on a 32mm.
So now the decision is between which of the brands will be the better preformer.
Tom
Posted 06/22/2006 04:37PM | Edited 06/22/2006 04:42PM #4
Tom:
You have gotten some good ideas here. I would like to add my thoughts as well as experiences as the owner of two 6 inch F/8 Dynascopes.
First, if yours is anything like mine, you will have a great time with it, the views are quite remarkable.
Second, yes a 32mm Plossl with have about the same TFOV as a 40mm Plossl, no doubt about it. But not everything is about field of view.
The 40mm will be significantly brighter. With a fast scope this is not an issue because one is always concerned about an oversized exit pupil and ones own astigmatism. However at F/8, the 32mm will have a 4mm exit pupil and the 40mm a 5mm exit pupil and in my experience a 5mm exit pupil is quite nice...
Thoughts and explanations aside, I have always considered the 40mm Plossl a silly thing because of exactly the reasons others have mentioned.
However that all changed the first time put a nicely made Japanese 40mm Kellner in my RV-6... Nice sharp, bright views, for some targets, these are my all time favorites regardless of scope or eyepiece. In the past I have compared the views to those of my 32mm Celestron Plossl and the result is that now I don't bother with the 32mm Plossl, I only use the 40mm MA when looking for a wide TFoV in these particular scopes. I have also compared the view to that of my 24mm TV Widefield, one of my favorite eyepieces, yet, I find myself sticking with the 40mm MA and a 25mm Ortho.. (Note the 40mm MA is a nicely made eyepiece, Japanese and Multi-Coated, no plastic here.)
So, I, just like most others, have often recommended the 32 mm Plossl over the 40mm based strictly on field of view alone but as I have discovered, there is more to the picture than just field of view. Certainly image brightness is something to consider here if the scope is slower as is the RV-6 at F/8.
I am sure either one will provide you with the widefield views you are looking for but my point here really is to share my experiences and point out that we should not be quite so quick in discounting the advantages of a longer focal length eyepiece in a slower scope.
Best wishes to all
PS: You don't need to spend $125 to get a decent 32 mm or 40mm Plossl. If I were looking and wanted the best possible, I would buy either a TeleVue 32mm or 40mm, or a 35mm Ultima. Both these are available used here on Astromart well within your limit.
Otherwise I would probably choose the Orion Highlight...
Posted 06/23/2006 05:09AM #5
Tom:
The 35mm Celestron Ultima, now discontinued but remaining stock is still available from many online dealers, gives the widest true field of view available in a 1.25" eyepiece. These are very high quality eyepieces and are made in Japan.
It is similar to the Orion Ultrascopic 35mm, but having owned both at different times, I think the Celestron Ultima is a bit more contrasty. It looks to have better coatings than the Orion unit had as well. It should be in the price range you specified.
Regards,
Jim
Posted 06/27/2006 06:00AM #6
For $130 I wouldn't bother with plossls if you want wide field low power and largest field of view possible in 1.25" format.
Speers Waler 18mm WA (if you can even find one) is hands down, the best eyepiece to fill this role in that price range. I bought one used for $90 and even in my F/5 G8n, it gives a very pleasing 80+ degree field of view, very comfortable eye relief, sharp to about 65 degrees and somewhat fuzzy beyond that but very dramatic views nonetheless.
Don't believe the hype, there is no comparison to true negative / positive lens group wide field eyepiece. There is simply nothing better for full field sharpness in this price range to fulfill your mission, unless you can find a 20mm Widescan. At f/8, a 20mm widescan (KK or UO brand) will match the speers waler 18mm for sharpness across the field of view, and will also show the full 1.25" image plane giving the widest possible field with your scope.
Ignore plossls, get a real wide field eyepiece! You can do it, troll the eyepiece ads and find an 18mm Speers Waler WA or 20mm KK or UO widescan. I guarantee you will be shocked looking through that soda straw plossl image after getting acquainted with a real wide field eyepiece!
