2" premium ep
Started by tomhole, 01/20/2004 01:55AM
Posted 01/20/2004 01:55AM Opening Post
I am in the market for a nice 2" widefield ocular. I will use it as a vista ep to provide me with a max TFOV (or close) for my 11" f/5.4 Starmaster. I don't wear glasses. Not young, not old (I guess they call that middle-aged wink. Heavy is actually good in my case as I have the Starmaster balanced for about 2.2 lbs of binoviewer and ep's. I can get away with .5 lbs either side of that without having to rebalance, which is preferred. Cost is a consideration in the bang for the buck sense. If it costs $600, I want $600 in performance. If I can get 95% at 1/2 that price, then I'm happy. Used is my primary target.
I am a binoviewer nut, so the best I can do right now is .75 deg TFOV with the 24 Pans in the binoviewers.
So, here's my list and I'm open for more suggestions:
EP: mag, TFOV, exit pupil, weight, price
41mm Pan: 37x 1.74 deg, 7.5mm, 2.1 lbs, $495
35mm Pan: 44x, 1.5deg, 6.4mm, 1.6 lbs, $365
31mm Nagler: 49x, 1.6 deg, 5.7mm, 2.2 lbs, $620
32mm UO MK80: 48x, 1.6 deg, 5.9mm, 1.2lbs ish, $295
Anything else? A guy in my club has the 32mm UO MK80 and our club has a 31 Nagler, so as soon as the weather breaks I plan to make a comparison between them. The UO is half the price and my man reports good performance in his f/5 Portaball. But until then, I want to see if the list needs to get bigger.
All inputs are encouraged and welcome.
Clear skies,
Tom
Posted 01/20/2004 02:25AM #1
I've been using the Siebert 36mm Observatory eyepiece very happily. 40mm field stop (light by your standards though)compares well with the 35mm panoptic in my f 5.7 dob, and costs $200. Never seen one listed used. It is certainly worth looking into.
I will be interested to see what happens with the UO MK80.
Posted 01/20/2004 02:35AM #2
Updated list:
41mm Pan: 37x, 1.74 deg, 7.5mm, 2.1 lbs, $495
40mm Pentax XW: 38x, 1.75 deg, 7.3 mm, 1.4 lbs, $549
40mm Pentax XL: 38x, 1.63 deg, 7.3mm, ???, $210 (used)
30mm Pentax XW: 51x, 1.3 deg, 5.5 mm, 1.6 lbs, $549
That 40mm Pentax XL looks like a nice option. The 7.3mm exit pupil isn't too bad and if I can find one, the price is right.
Tom
