Mark Eby
M33 Triangulum Galaxy
24mm Panoptic vs. 28mm Siebert Ultra
Started by mkawada, 06/18/2006 04:04AM
Posted 06/18/2006 04:04AM Opening Post
1750mm F/4.5 Dob.
Televue Panoptic 1.25"
- .93 true FOV
- 73x mag
- 5.3 exit pupil
- $310 new, would be used though
Siebert Ultra 1.25"
- .96 true FOV
- 63x mag
- 6.2 exit pupil
- $140 new
If the TV is significantly better it will justify spending the extra money for a used one over a new Siebert.
Posted 06/18/2006 03:40PM | Edited 06/18/2006 03:41PM #1
All these "my eyepiece is better then yours" threads of late are all relative - Only YOU can determine if its worth the extra dollars. Keep in mind the difference in most cases between premium vs. average and good eyepieces are rather subtle. In many cases only experienced observers will see/notice the difference.
When you hit that point you'll wonder why you never noticed the Naglers were so much better. For me the fit and finish, quality build, versatility of a design able to go from f4 to anything longer, and the resell value all add up to being worth it. But that's me. I learned a long time ago - granddad was right - you get what you pay for in the long run....
Posted 06/19/2006 02:26PM #2
I think this decision will have more to do with other factors than just EP performance, because of the great difference in price mostly and how well you can handle your own expectations.
I don't have a Pan, just its predecessor, the 24mm TV Wide Field. I have a few Ultras, 15mm and smaller FL though. So really can't do an apples to apples comparison at all. However, the two EPs do leave me with distinctly differing feelings after use. I come away slightly more "pleased" when I use the WideField, but it is never "transparent" -- i.e., always realize I'm looking thru an EP-window. The Ultra, on the other hand, leaves me more of a memory of what I observed rather than the glass I'm observing through.
But all other things aside, both EPs are good. And after you forget about the EP you are using and concentrate on the business of observing, you have to ask yourself if you would have been happier with 2 EPs instead of 1 for the same money?
We all want the best. The "expectation" to contend with is do we all need the best? A difficult issue.
In another thread, someone referred to William Hershel. Take a moment to read a small part from his log regarding volcanoes on the Moon (http://www.space.edu/moon/timeline/1700s/1787-Herschel.html). It is really refreshing. At no point does he mention the instrument he is using, nor the eyepiece design. Seems for some reason, this observer's focus is solely on that which he is observing. Really nice to read. Plus in the 1st para he understands the limitations and biases of his own mind in the process.
I don't know, but after reading this, I'd go for more observing tools (i.e. EPs) over just having one. Sometimes, having one more perspective in a slightly different magnification, let's us see more.
Good luck with the quandary smile
