I'll cut to the chase: this is a splendid eyepiece! I tried it this evening in my 16" f4.5 dob as twilight fell and the clouds drifted away. Seeing was a 3/5. During periods of relatively steady seeing, and without a paracorr, coma was present at perhaps 75% outward or so but seemingly more suppressed than the 16mm version. Eye relief seems less than the advertised 22mm but it's more than enough. The eyepiece is immersive in the views it provides and it has the look, feel and performance similar to a high end unit.
While the views are decent enough without a paracorr, adding one significantly improves the edge performance so coma is not an issue. There is more lateral color at the extreme edge than the 16mm, and it appears as a bluish tinge to a bright star but is otherwise not a problem unless you care to look for it at the field stop.
I looked at Mars but other than being able to see it was Mars, there really wasn't much detail to discern, given its tiny, receding disc.
Obviously, this eyepiece is meant for widefield views of clusters and extended objects and I doubt it will disappoint observers in this regard. It doesn't have an 82 degree field but it is quite respectable in what it delivers, especially at its current price point.
If you've got a fast scope and a paracorr and you're looking for a longer focal length eyepiece that won't break the bank, jump on it.
BTW, I found this CN report on the same model, also tested on a fast scope:
http://www.cloudynights.com/item.php?item_id=1270
