Hi folks...
For the last several years I have enjoyed many views through my beloved 32mm TeleVue Widefield, lots of great memories in a great variety of scopes with this eyepiece, it gives me what I call a "big, easy view" - enough eye relief and a big field lens, I can easily see the whole field of view without trying.
It is not without it's faults, it's field stop is a tad bit over 33mm which makes the effective AFoV only about 60 degrees, it's edge correction in a fast scope (F/4.06 + Paracorr) = F/4.7 is acceptable but not sharp like the old 16mm Nagler Type 2. The biggest issue I find is the pincushion distortion when scanning the sky on a dark night, sea sickness is possible...
So enter the 35mm Panoptic... A good deal on Astromart and I "upgraded" to the 35mm Panoptic. Bigger, better edge correction, wider field of view with its 38.7mm Field stop... It has gotten a lot of use in the last few months and even in my faster scopes (operating at F/4.7 and F/5 with the Paracorr) the edge is very good and simply wonderful in my F/7 ED/APO refractors... That old Widefield has just sat there in the eyepiece case... neglected
I spent 4 nights in mountains over Labor Day, Thursday night I decided to do a quick comparison in my 12.5 inch F/4.06 Discovery operating at F/4.7 with the Paracorr, nothing too technical, just what was my impression of the difference in the views...
(Note: in this scope, both these eyepieces push the nominal 7mm exit pupil limit, the 32mm provides 6.8mm, the 35mm provides 7.4mm. Not knowing my maximum pupil opening, I take the eyepieces as the are)
- These eyepieces are more alike than they are different. Both an nice and sharp in the center of the FoV. Both are evenly illuminated across the field of view, no bright edge region here. The views of the Wild Duck at 45x are impressive in both. I was surprised that after becoming used to the Panoptic that the 32mm Widefield still provided acceptable edge sharpness. A careful evaluation would show that the Panoptic was cleaner...
- "Big, Easy View..." I have to say that the 32mm Widefield was the winner here. More eye relief? Bigger eye lens?? Not quite sure but with the Panoptic I find I need to get closer to the eye lens and pop the rubber eye cup down.
- Total field of view... The 35mm Panoptic is the clear winner 1.5 degree to 1.28 degree TFoV... makes finding things a bit easier.
- Pincushion/getting sea sick... I love wandering around the Milky Way with these eyepieces but neither one is "orthoscopic." I was definitely less bothered by the 35mm Panoptic... can't make any claims as to why but when wondering around Sagittarius with the 32mm WF, I definitely noticed the "distortion" of the star field as I moved the scope. It was also apparent in the Panoptic but did not seem to bother me as much.
Bottom line... I am definitely keeping the 32mm Widefield but the Panoptic is the workhorse here. In the past I have said the 32mm TV Widefield is a reasonable choice as an affordable widefield eyepiece in a faster DOB and I think that is still true. This is not to say one should pay $200 for one but I think for $150 or less, it does a nice job.
that's my two cents and I am stickin with it even if I am wrong...
