I am buying a new low power eyepiece and I'm building a 10" f5.24 dob. The choice has come down to these 2 eyepieces and they are the same price. I have been told that I will be pleased with the Hyperion but Siebert's website claims it's field will be completely without distortion at f5.24. Is that true? Has anyone compared or used either of these eyepieces in a similar optical configuration?
36mm Hyperion Aspheric vs 36mm Siebert Observatory
Started by dreamregent, 05/28/2009 11:03AM
Posted 05/28/2009 11:03AM
| Edited 05/28/2009 11:04AM
Opening Post
Posted 05/29/2009 10:58PM
#1
Well, I owned a 34mm Siebert Observatory for a while, using with a 16" f 4.9. There was definite astigmatism in the outer areas, say 20%. I would not believe Mr. Siebert's statement to be totally correct about no distortion at f/5.2, unless he is referring to lack of pincushion.
Pincushion would show as bent lines in daytime, or as stars seeming to follow curved lines while you move the view around. Pincushion can cause a little bit of nausea like seasickness if you pan around too fast.
The Televue Panoptic, which is more expensive, supposedly trades low astigmatism for higher pincushion, from what I have read. I think the Siebert Obs goes the opposite way and has low pincushion.
If it were me, I would take the low astigmatism and get better stars when the telescope is not moving. I think you will detect some astigmatism from the Siebert, which is normal for less expensive eyepieces in fast scopes.
The Baader I do not have experience with.
Hope that helps.
Mike
Hope that helps.
Mike
Funding Member
