For purists, 1mm of difference in focal length makes a direct comparison a mute point. However, there has been a relatively high amount in curiosity among amateurs in regards to 9mm ES vs the Ethos 10mm, at least on other sites. So to answer the question, I attempted a comparison of the two last night under conditions of good transparency and very good to excellent seeing in suburban light pollution in front of my home. I'm thankfully able to see the milky way overhead and with the aid of an O111 filter, I can see the Veil nebula reasonably well with my longer focal length eyepieces in my 16" f4.5 dob.
I was able to pull in a planetary nebula in Cygnus last night with a magnitude of 12.3 without a filter. NGC 6894 is fairly large at 45" x 40" and I have to say it appeared a bit better in the 9mm ES than in the 10mm Ethos. This may simply be a matter of the increased magnification darkening the sky a bit more in the ES than in the Ethos but the view was better in the 9mm than in the 10. Score one for the ES. Next, I compared the view of the fetus nebula(ngc 7008) with and without a filter and came to the conclusion I could see a bit more subtle mottling in the Ethos than in the ES. This may be due to the apparent brightening of the image due to a decrease in magnification. Nevertheless, score one for the Ethos. Next, I observed a fairly bright galaxy in Pegasus, NGC 7331. At magnitude 9.5 and with a size of 10.5' x 3.7", this nearly edge on galaxy was easy in both eyepieces without discernible differences so I'd rate this one a tie.
With Jupiter rising higher in the sky, I took advantage of the good seeing conditions to put these eyepieces through their paces. Before I begin the discussion, it should be noted there was a lot of activity on Jupiter during the nearly three hours of observation on Saturday night. The large oval nearly colorless spot was easily visible even in my longer focal length 24mm ES eyepiece. A smaller red spot appeared in one of the belts and multiple bands were easily discernible. The first thing you notice when you swap the ES and Ethos eyepieces on Jupiter is the greater amount of glow or scatter about the planet in the ES than in the Ethos. The views of the details on the planet were essentially similar but the glow around Jupiter was a bit of a distraction. Score another point for the Ethos as it appears the coatings on the Ethos may be superior. My impression is the color saturation of the belts, bands and spots is the same in either eyepiece but the surrounding glow around the planet was more suppressed in the Ethos. I also felt the Ethos barlowed better than the ES but this could have been due to increasing magnification and not some other factor.
Both eyepieces did quite well in flatness of the field and with a paracorr in place, I could not detect coma. Other optical aberrations such as lateral color and astigmatism are well controlled in either eyepiece. I was pleased with the overall comfort level with respect to eye relief in the ES. I was able to take in most of the field of view without having to peel my eyeball off the lens. I feel the ES 9mm 100 is a well executed 2" design. OTH, the Ethos can function both as a 1.25 eyepiece and as a 2" ocular. I found the latter to be helpful when using the Ethos in older scopes with a 1.25" focuser and when using my Orion 1.25" broadband filter to suppress the light pollution in my area.
Cost is another factor and one in which the ES 9mm wins hands down. This is a fine ocular and at current sale prices, a very real deal.
If I had to choose one, I'd go with the Ethos as the uncompromising choice. The ES is hot on its heels and gives up very little to the Ethos. You will likely be pleased with either eyepiece. If you want that little bit of extra black around Jupiter, you'll get it with the Ethos but even so there's still some glow as the light bounces off multiple lens surfaces before reaching your eye. It's certainly not all black and white...
