I was wondering what would be a logical approach to putting together an eyepiece collection? I am strictly a visual observer, and I am now getting to the age where eye relief is important. Thank you, Bill
A logical approach to eyepieces?
Started by Bill in Ballard, 01/28/2012 11:30PM
Posted 01/28/2012 11:30PM
| Edited 01/29/2012 12:54AM
Opening Post
Posted 01/29/2012 01:44PM
#1
There are those who like to have a specific eyepiece for every possible combination. There are others (like me) who say that, for any given scope, you need only three eyepieces.
With that in mind,
Get the highest quality you can afford
Consider buying used
Get the widest Apparent field of view you can afford (At least Plossl's (at 50 or so degrees), and 82 degree Naglers/Ultra-wide class if you can afford them)
Space them so that, when using a 2 power Barlow, you double your eyepiece set. (Don't, for instance have a 25, a 12 and a 6. Instead think 25/15/9. If you then use a Barlow doubler, you get 25/15/barlowed 25 or 12.5/9/Barlowed 15 or 7.5/Barlowed 9 or 4.5. (If you would have used a barlow on a 25/12/9, you would still have only a 25/12/9/4.5)
Consider exit pupil, and do not get anything larger than 7 mm exit pupil if you are young, or 5 if you are an old fart. Your eyes only get so big (depending on age) and having an exit pupil bigger than your eye generally wastes photons.
If you are talking a reflector with a central obstruction, don't get anything so long as the shadow of the central obstruction will show up.
Don't get an eyepiece that will result in a magnification of more than 250 or so power unless you have particularly good seeing. (The sky will not let you use it very often.)
Get one that gets you a high magnification, one in the middle, and one with the lowest magnification-- consistent with the restrictions on seeing and exit pupil mentioned above.
That is my advice.
With that in mind,
That is my advice.
Posted 01/29/2012 03:27PM
| Edited 01/29/2012 03:28PM
#2
There are four "magic" focal lengths that you should cover in your collection. I call them Maximum Field, Maximum Starlight, Maximum Definition, and Maximum Resolution. These are not specific millimeter values but depend on your telescope and your eyes.
The Maximum Field eyepiece shows the widest actual field of view possible in your scope. If you have a 2" focuser you should look for eyepieces with a Field Stop of around 40 millimeters, or 27 millimeters for a 1.25" focuser. You can estimate the Field Stop by multiplying the focal length by the apparent field and dividing by 60. The exit pupil may be too large for your eyes, but the whole point is to get as large a field as possible although some star brightness might be sacrificed.
The Maximum Starlight eyepiece shows as many stars as possible at full brightness. The exit pupil should exactly match your eyes (or maybe slightly smaller to allow for misalignment). The exit pupil of the eyepiece equals the focal length divided by the telescope's focal ratio.
The Maximum Definition eyepiece shows faint planetary detail as well as possible. Many observers agree that definition is best when the exit pupil is about 1 millimeter (25x per inch of aperture). The focal length of this eyepiece should equal your telescope's focal ratio.
The Maximum Resolution eyepiece gives the highest usable magnification, usually 50x per inch but this may be too high for telescopes larger than 10".
I like to have ratio of about 1.6 to 1 between magnifications. This meshes perfectly with a 2x Barlow if you want really close spacing.
Funding Member
Sponsors
- Anacortes Telescope
- CarbonScopeTubes LLC
- FocusKnobs
- APM-Telescopes
- astronomy-shoppe
- OMI OPTICS USA LLC
- RemoteSkies.net
- BW
- Waite Research
- SellTelescopes.com
- kwtelescope
- Astromart Customer Service
- Vernonscope
- Matsumoto Company
- AstroMart LLC
- BBLABS LLC
- Desert Sky Astro Products
View all sponsors
